test alternator
Old Oct 12, 2004 | 02:43 PM
jrfoscue's Avatar
jrfoscue
test alternator
How do i check my alternator on my '79 F150 390?
Old Oct 12, 2004 | 03:36 PM
paragod's Avatar
paragod
You can take it or the whole truck to the local parts store, and they will test it. I know that Autozone will check it on or off the vehicle.
Old Oct 12, 2004 | 04:29 PM
WillyB's Avatar
WillyB
Use a voltmeter - measure voltage at the battery before you start it, and again when the engine is running - maybe above 1500 or so RPM. Should read 12.6 or so before, and 13 to 14 volts when the alternator works.
Cheap voltmeters are not real accurate so just look for a volt or better increase when the alternator charges. Also, a low battery will draw the voltage down and will need to charge a while before you reach max voltage.
