alternator clearance
Old Oct 12, 2004 | 06:53 AM
gromelc's Avatar
gromelc
1987 F150 4X4, 302 fuel inj. I was changing my belt the other day and saw this and wanted some info. The adjustable tension pulley for the belt was off center. When I moved it up to make room for the new belt ,the pulley and the alternator( which it's attached to ) both move in and out.. The alternator is mounted on the motor but ,, its about a quarter inch from sitting flush with the motor. As your looking down on it there's a threaded stud on the left but nothing on the right. Finally ,my question is, is there a bracket missing ,that's fell off, or did the bolt just loosen up . And also whats the proper space that should be there?
