Sponsored by: Real Truck
ABS - Speedometer cable
Old Oct 12, 2004 | 05:07 AM
icyford's Avatar
icyford
Hi there
Im not sure wether its ok to post this question here, but I will give it a try.
In my F250 I did connect Truespeed Calibrator from Superlift. It was connectet to a gray/black wire from the ABS sensor.
Do you know if its possible to install Truespeed calibrator in Econoline (new), and if so to what wire?
Old Oct 12, 2004 | 11:49 AM
RealMenPowerstroke!'s Avatar
RealMenPowerstroke!
Originally Posted by icyford
Hi there
To my knowledge beacause of the different systems used it would most likely be a different TruSpeed. In which case it would tell you the color wire in the directions.
Best of Luck,
Corey
Old Oct 12, 2004 | 02:11 PM
icyford's Avatar
icyford
Speed sensor
"because of the different system"
Is the ABS and speed sensor much different in Econoline. (Compared to Superduty)
