Any Throttle Position Sensor Secrets?
Old Oct 11, 2004 | 11:01 PM
90F1505.0L's Avatar
90F1505.0L
Hey I heard that the TPS voltage can be adjusted one way or another to get some extra ponies out of my 5.0L. Once again looking for some help.. thanks in advance again....
Old Oct 12, 2004 | 06:50 AM
EPNCSU2006's Avatar
EPNCSU2006
It needs to read about .8-.9 Volts at closed throttle with the key on. Don't know that you'll get any extra power though.
Old Oct 12, 2004 | 07:18 AM
Blurry94's Avatar
Blurry94
The TPS trick doesn't do anything, you'd be better off to advance your timing if you want to pep it a little.
Edit: just read your other post. If it's already pinging then back the timing down or run better (higher octane) gas.
Old Oct 12, 2004 | 08:24 AM
90F1505.0L's Avatar
90F1505.0L
I am running high octane gas, it does it when i am coming up through 3rd and 4th.
