dumb c6 question
Old Oct 11, 2004 | 10:50 PM
Beastybroncothe2nd's Avatar
Beastybroncothe2nd
dumb c6 question
since i lost my old password and had to get a new screen name i cant search the forums until i post some and i need some specific info on changing the tranny fluid in my c6
i need to know how many quarts of fluid?
i think i will stick with type F unless yall think i should go with a newer fluid?
i have a external cooler and i was wondering if that would be the best way to change the fluid in the torque converter? which line is the return line?
i think i should drop the pan and check for metal shavings other than replacing the gasket is there anything else i should change?
should i use a specific type of sealant on the gasket?
i would greatly appreciate someone answering these questions and/or linking me to a good thread
Old Oct 12, 2004 | 12:03 AM
swgaspidey's Avatar
swgaspidey
A local transmission shop suggested going to mercon trans fluid it builds up pressure easier than type F.
Old Oct 12, 2004 | 09:49 AM
Beastybroncothe2nd
mercon V right not the stuff with dextron in it?
Old Oct 12, 2004 | 06:04 PM
swgaspidey's Avatar
swgaspidey
If you can find it that way or you can go the other way. By the way a fliud change is usualy 10 quarts some times more.
