Bronco II Ford Bronco II
I'll try again--'86 Bronco2 Engine surging
Old Feb 25, 2000 | 03:31 AM
tamarack69's Avatar
tamarack69
Got an '86 Bronco2 with 2.9L V6. It will sit and idle or run along good then suddenly start acting up RPM will drop, engine will start to miss, then just as suddenly, it'll pick up again & act fine--any ideas ??
Old Feb 26, 2000 | 07:09 PM
FTE Ken's Avatar
FTE Ken
You'll probably have better luck in our Bronco 2 or Ranger forum. [img]/dcforum/Images/happy.gif[/img]
Old Feb 27, 2000 | 06:37 AM
jmac's Avatar
jmac
sounds like a problem i had with my f-150 5.0
finally found out that it was the o2 sensor.
good luck
jmac
Old Feb 27, 2000 | 08:01 PM
andy_1's Avatar
andy_1
Old Dec 16, 2004 | 09:55 PM
Russ86B2's Avatar
Russ86B2
check for a leaking, bad seal, gasket...etc. My tank seal was bad in my 86 and was causing a surge while ideling...
Old Dec 16, 2004 | 09:59 PM
mrshorty's Avatar
mrshorty
Especially on an '86 that doesn't have a check engine light, the best first step is to pull any codes from the computer. Ken00's tech info post has info on doing this. Requires nothing more than a paper clip and a voltmeter/test light.
Old Dec 17, 2004 | 04:57 PM
Ken00's Avatar
Ken00
Just an FYI, this thread is from 2/25/2000.
irly
6.7L Power Stroke Diesel
Nov 9, 2016 03:27 PM
metaldrums
Bronco II
Oct 12, 2011 10:21 AM
montymbad
Nov 28, 2006 04:49 PM
tomaurand
Bronco II
Apr 11, 2005 12:39 PM
redbronco2
Bronco II
Jul 27, 2001 01:48 AM
