Bronco II Ford Bronco II
What size tires...
Old Jan 5, 2000 | 08:23 PM
gimps's Avatar
gimps
What size tires...
I have an '86 Bronco 2. Right now, it has LT235x75R15 radial tires, and a 2" or 2.5" lift. I'm currently looking to get some larger tires, and looking at the Mickey Thompson Baja's, 29x11.50x15. But, the thing is, I'm not sure if they'll fit without a larger lift.
Has anybody tried using 29x11.50x15 wheels, without a lift larger than 2"?
Thanks,
Jeremy
Old Feb 27, 2000 | 08:27 PM
andy_1's Avatar
andy_1
What size tires...
Have a stock, no lift, stock rims, 1989 bronco2 with 30x9.50 AT's, they fill the fender wells, no rubbing at all, looks great, the probem with going wider may be rubbing the radius arms unless you get rims that outset the tires.
Old Feb 29, 2000 | 05:14 PM
Trail_Rider's Avatar
Trail_Rider
What size tires...
235's are usually in the 28" range and you're going to 29's, shouldn't be a problem there cause all you're doing is going wider. The only problem I can foresee with that width is perhaps hitting the fenders when turning and like the above post hitting the radius arms unless you get wheels with the proper offset. If you move the wheels out you're going to increase the chances of fender clearance.
Trail Rider
Old Feb 29, 2000 | 05:16 PM
Trail_Rider
What size tires...
NativeDescent
Jul 29, 2015 09:52 PM
navigatorstang
Apr 12, 2010 01:17 PM
Nightrain
1983 - 2012 Ranger & B-Series
Apr 20, 2009 09:28 AM
ratman-73ford
Offroad & 4x4
Aug 21, 2004 02:53 PM
RonF150
Nov 27, 2002 09:51 PM
