302-351 Engine Swapping Question...
Old Oct 11, 2004 | 08:22 PM
IMAFORDBOY's Avatar
IMAFORDBOY
Exclamation 302-351 Engine Swapping Question...
Hey guys, my 302 in my '91 F-150 doesn't have compression in one of its cylinders. I'm aware that this could be for a large number of reasons, but my best guess is (since there was a lump of metal on the bottom of the spark plug for that cylinder) that I blew a hole through the cylinder. Hopefully this isn't the case, and I'm looking into what the case is right now, but if it is then I might as well swap it out for a 351 windsor. My friend told me however that this would be more difficult than I suspect, and that certain parts wouldn't match up right. I'm no expert when it comes to swapping out an engine, but I would think its possible. Could anyone tell me what, if anything, would keep me from swapping in a 351? Thanks.
Old Oct 12, 2004 | 07:26 AM
Blurry94's Avatar
Blurry94
I don't think you will run into any major problems with that swap...many have done it before. The exhaust may need to be modified being that the 351 is a bit wider. The PCM will run it too, but if you can get the one that goes with the 5.8 you're using, then great. One of the things you may want to look for is an F4TE casting number. Is means that the block is drilled and tapped to accept a spider for a roller cam conversion. If you decide to go with a roller cam then you'll need to change out the distributor gear to a steel one. The gear can be purchased and pressed on, or you can buy a distributor assembly for a 96 or early 97 5.8 and it'll already be on there. I think they're only 90 bucks from Auto Zone.
Old Oct 12, 2004 | 08:31 AM
frederic's Avatar
frederic
Blurry is right, its not a complicated swap. YOu will need the 351 manifolds, flywheel, clutch etc in order to do the swap. The great thing about the swap is the F-series could be had with a 351W, so all the parts are available from dealers, autozone, and ebay. It will bolt right in.
There are enough 5.8L cars and trucks in junkyards, you can get most of the parts you need. I'd use a new clutch and new motor mounts, new water pump and new oil pump as a minimum however, just to be safe.
Old Oct 12, 2004 | 01:50 PM
MustangGT221's Avatar
MustangGT221
Yeah I'm actually doing the swap right now. The bracketry should bolt right up, you can re-use the manifolds but it would be a good time to get some headers, and a new y-pipe, bassani has some nice ones. A quick search on our site will pull up a lot of info on this swap...it's been talked about many times.
Old Oct 12, 2004 | 02:31 PM
GoinFishin's Avatar
GoinFishin
<TABLE class=tborder cellSpacing=1 cellPadding=4 width="100%" align=center border=0><TBODY><TR title="Post 2025934" vAlign=top><TD class=alt1 align=middle width=125>MustangGT221</TD><TD class=alt2>Yeah I'm actually doing the swap right now.</TD></TR></TBODY></TABLE>
Mustang - I hope you are taking pictures, notes etc. What computer are you using? Any major difficulties so far? What did you get the donor motor out of? (I want to do the same)
Old Oct 12, 2004 | 06:05 PM
brown 4x4's Avatar
brown 4x4
Just to be a little more clear, the exhaust manifolds can be reused. The 351W lower intake is wider than the than the 302's though, so you'll have to find at least the lower intake manifold from a 351W.
