1978 - 1996 Big Bronco
Dynamat advice?
Old Oct 11, 2004 | 03:49 PM
JBronco's Avatar
JBronco
Dynamat advice?
I have the following pieces of Dynamat:
6 sheets of Original Dynamat, each sheet: L=32", W=18", Thickness=0.075"
4 sheets of Dynamat Xtreme: L=32", W=18", Thickness=0.085"
And two sets of Dynamat Extreme door, one for covering each door.
I am going to use the door kits to cover the doors. I am not positive where to put the rest for maximum soundproofing and speaker response.
I want to put some around each of the 6X8 rear speakers. After that, I am not sure. I was thinking of covering the tailgate with the Dynamat original, the window motor is new so that is not an issue, and I have a piece of diamond plate cut to fit that covers the inside of the tailgate so the Dynamat would be sandwiched between that and the tailgate.
For the rest, I was thinking of putting some under the driver and passenger side carpeting, on the floor.
How does this sound? I also will be getting a Dynamat hood liner one of these days, so I don't need to put any under the hood.
Old Oct 11, 2004 | 04:30 PM
ojosdestranger's Avatar
ojosdestranger
I had a post on this subject... I got a lot of feedback...
Search "Soundproffing idea"
- Stranger
