Sponsored by: Kumho
Power steering pumps
Old Oct 11, 2004 | 03:39 PM
Frankul2003's Avatar
Frankul2003
i bought 3 different power steering pumps and they all wont work on my 78 F150 4wd .. i need to know what is happening.. why arent the pumps working..??
Old Oct 11, 2004 | 04:43 PM
alcan60283's Avatar
alcan60283
What doesn't work? Please be more specific. Does the pump not fit? The pulley won't go on, or does it not pump fluid. We need some more info to help you.
Old Oct 11, 2004 | 04:55 PM
Frankul2003
more info
no the pump goes on fine and it works for like a day then the next day when i start it ,.. it is stiff as hell and wont work .. and i went through 3 pumps and they all did the same.. what else would be wrong..??
Old Oct 11, 2004 | 06:02 PM
Djoffroad's Avatar
Djoffroad
Have you bled the system?
Old Oct 11, 2004 | 06:48 PM
alcan60283's Avatar
alcan60283
Sounds like you have a lot of air in the system. You need to bleed it. Raise the wheels off the ground, and support the truck by the frame. Turn the wheels from lock to lock, back and forth and it should work the air out. You might have to do this MANY times, but it will work. If it doesn't, you might need to make a vacuum pump to get the rest of the air out. Try the first method before anything.
Old Oct 11, 2004 | 07:19 PM
Mil1ion's Avatar
Mil1ion
https://www.ford-trucks.com/forums/s...d.php?t=102632
Old Oct 13, 2004 | 10:09 AM
73Custom's Avatar
73Custom
Be sure to flush the system. There are lots of grit and filings in the hoses and box. And if these get into the new pump they will ruin it in a matter of hours... I like to install the new pump - but leave the return hose off and plug that spot on the pump. Then fill the pump and run the engine a couple seconds, stop and refill - no longer or you will run it dry and also ruin the pump. Keep doing this until the fluid coming out is as clean as the new fluid going in.
Marty
Old Oct 14, 2004 | 07:10 PM
Frankul2003
ok i got it working pretty good . .but it still has stiff spots some times
Old Oct 14, 2004 | 09:41 PM
ford390gashog's Avatar
ford390gashog
install a power steering filter
Old Oct 14, 2004 | 10:18 PM
Torque1st's Avatar
Torque1st
Posting Legend
Wix transmission/PS filter
Wix transmission/PS filter #58964
200 psi working, pressure relieved, magnetic
change yearly or 12000 miles
Ford equivalent filter kit #XC3Z-7B155-AA
filter alone #XC3P-7B155-BA
Old Oct 14, 2004 | 11:33 PM
ford390gashog
the filters are 2.50 at napa
Old Nov 4, 2004 | 09:43 PM
Frankul2003
Smile i got it
i figured out what it was.. it was the steering wheel bearing .. it was all messed up and kept giveing me stiff spots and hard steering
Old Nov 6, 2004 | 11:20 AM
Brad Brown's Avatar
Brad Brown
I have soom issues too.
I have a 74 with a coversion from a 78 installed. It seems the pump is not getting enough pressure at low rpms so the steering stumples a bit , squeals like a pig and grunts a bunch at low speeds in tight spots.
Would a smaller pully fix this problem? Maybe?
Old Nov 7, 2004 | 04:13 PM
Frankul2003
brad
did u buy a new pump?
and if so did you buy it from a NAPA or an AdvanceAutoParts store?
