I received my predator tuner last week and installed the 65 HP program and everything went well. Then this morning I plugged in the Predator to pull my diagnostic codes and nothing will come up. The screen stays blank like it is not receiving any power.
Has anyone else experienced similar problems?
I called Motorhaven and they are shipping out a new one, in a few days when they get them in, but just in case I don't want to risk not being able to return the stock tune.
I have not had this problem. If you need to return your truck back to its original "stock" mode, I guess you will have to remove the batteries for a period of time.
Anyone know of another way to "reset" your truck if the predator fails? (I have my original backed up on my laptop)
You can save your original tune to your PC or laptop. I have done it and so has Bob. It is not a very large file. I think you could send it to Diablo and have them reload it into your Predator. If you sent them your Predator that doesn't work, they might be abloe to recover your original tune.
If you do, you need to have your computer, the dowload program, and the Predator all set for the same transfer speed or it won't work. Read the instructions carefully and folllow them exactly and it will work.
