Sponsored by: Auxito
Tire Issues
Old Oct 11, 2004 | 08:51 AM
cajunrouge's Avatar
cajunrouge
Exclamation Tire Issues
Can anybody help? I have a 2000 F-150 4x4 and need suggestions on changing a rear tire. Bought the truck used, so I have no manual. Anyway, I can remove the lugs but there is a rusted cap in the center of the wheel that is not moving and I can't get the tire off.
Old Oct 11, 2004 | 09:23 AM
karenj's Avatar
karenj
Try appling some penatrating lube around that area and let set and with jack stand under truck use your foot and kick it. I rub a light coat grease around that area to keep that from happening you can try that.
Old Oct 11, 2004 | 10:39 AM
cajunrouge's Avatar
cajunrouge
tire still stuck!
Thanks for the advice. Tried that with no luck.
