Bronco II Ford Bronco II
V-8 engine swap
Old May 18, 2000 | 05:22 PM
old timer's Avatar
old timer
V-8 engine swap
Has anyone ever done this before or thought of doing the swap. I got a 1990 bronco truck complete with the motor, trans, transfer case and all. this is the 5.0 EFI. I am mainly concerned about any fabrications that will have to be made for the conversion. Also, I am wondering, the transfer case on the Full size Bronco has the motor assembly for push button 4x4. My bronco II has manual locking hubs. Will this also create a problem. Thanks for all input.
Old May 18, 2000 | 05:27 PM
old timer's Avatar
old timer
V-8 engine swap
I didn't even see the post below, it has alot of good info, but anyone who has personally done this, I would like to know what you thought about the whole process
Old Jun 25, 2000 | 03:52 PM
gimps's Avatar
gimps
V-8 engine swap
Old Jun 26, 2000 | 05:35 PM
boodlum's Avatar
boodlum
V-8 engine swap
I am in the process of putting in a 302 in my BII. As for running gear, I am getting a T-5 from a mustang and same with bellhousing/oil pan/motor mounts. As for EFI, I wouldnt touch it with a 10ft pole. Plus my 650 double pumper will kick butt on a stock EFI unit any day
