Steering box fit through floor?
Old Oct 11, 2004 | 06:57 AM
oldjeep's Avatar
oldjeep
Maybe I was just too tired last night, but I'll ask anyway. I pulled the plates off around the steering column so I could pull the column and box out of my 53. I tried every concievable angle but couldn't find one that would allow me to pull the box into the cab. Is there some special trick to it, or does it just not fit through the floor hole?
On the plus side I did get the cab disconnected and pushed back tot he rear of the frame so I can get going on the new crossmembers.
Thanks
Chuck
www.oldjeep.com
Old Oct 11, 2004 | 03:38 PM
fking1's Avatar
fking1
Believe the 53 & 55's are the same. No trick, but, my 55's came through the hole. Did take the steering wheel off as it is awkward with it on.
Fred K.
Old Oct 11, 2004 | 04:34 PM
Fat Fendered Ford's Avatar
Fat Fendered Ford
I also pulled my steering gearbox up through the floor after first removing the steering wheel.
Kevin Kessler
1953 Ford F-100
Old Oct 11, 2004 | 04:45 PM
oldjeep's Avatar
oldjeep
I'll give it another shot. If I could get the steering wheel off, I'd just drop the column out the bottom
Old Oct 12, 2004 | 04:59 PM
jaye's Avatar
jaye
I pulled my 55 through the floor however, if you dont need the steering box cut the tube close to the box and drop it on the floor.
Jaye
Old Oct 14, 2004 | 06:45 AM
oldjeep's Avatar
oldjeep
Found the magic position and got the box through the floor tonight. Next step is to move my rock-crawler into it's winter home in the other garage so I've got space to really start working on the truck.
Chuck P
www.oldjeep.com
