knock under load
Old Oct 10, 2004 | 10:00 PM
del250's Avatar
del250
knock under load
Just got the engine (351m) back together after a stuck valve and bent push rod and I get a knock under load. Oil presure is fine, slight pinging. Could the timing couse a knock.
thanks Derek
Old Oct 11, 2004 | 07:35 PM
danlee's Avatar
danlee
Timing will cause pinging, but a true knock is an indication of a mechanical problem like a bearing. Try to pinpoint the location of the knock (high or low) to determine the probable cause.
Old Oct 11, 2004 | 09:39 PM
del250's Avatar
del250
Sounds low. Is there a way to tell if its a main or rod bearing.
Old Oct 12, 2004 | 07:00 AM
danlee's Avatar
danlee
How is your oil pressure. Low oil pressure would point to a main.
If you disconnect one spark plug at a time, and find a cylinder where the knock goes away. Then it is the rod bearing for that cylinder. You could drop the pan and replace that rod bearing or all of them, if you don't want to do a complete rebuild.
Old Oct 12, 2004 | 10:06 AM
del250's Avatar
del250
oil pressure is good, I will try disconnecting the plug wires. Not realy wanting to do a complete rebiuld yet. Future project. thanks
