1978 - 1996 Big Bronco
solid axel conversion
Old Oct 10, 2004 | 06:23 PM
demonspeeding's Avatar
demonspeeding
i have a 96 bronco i would like to beef up the rear end it has an 8.8 with a locker and would like to convert to a soild up front i'm running 38 super swampers and the axels just can't take it i'm thinking a dana 60 in front and dana 70 outback any suggestion on how to do this and if theres any conversion kits out there and any suggestions on what type of axles to use
Old Oct 10, 2004 | 06:49 PM
WhëëlMå1's Avatar
WhëëlMå1
Welcome to FTE demonspeeding. I know it has been discussed before. You should use our search function, and search for 'SAS', or 'solid axle'. Good luck with your swap.
Rich
Old Oct 10, 2004 | 06:52 PM
demonspeeding
thanks for ur help
Old Oct 11, 2004 | 02:03 PM
Kemicalburns's Avatar
Kemicalburns
you cant swap a d60 in the rear. must be a sterling 10.25. as for the front a hp60 would be your best choice for strenght
Old Oct 11, 2004 | 06:20 PM
oldhalftons's Avatar
oldhalftons
A d60 rear won't have the ABS trigger wheel, but it will bolt right in.
both the D60 and the sterling will need drivshaft work
Old Dec 20, 2004 | 04:48 PM
rlh's Avatar
rlh
Actually, this can and has been done. Go to fsb and search around.
Old Dec 21, 2004 | 11:50 PM
plugly's Avatar
plugly
you can get a d61 out of a van that has the tone ring sensor in it, but no 60's came with one. you can adapt one in, but that requires some special tools and skills.
A sterling rear is an easy swap.
A 60 front swap requires a lot of work, but so does a 44 for that matter. wether coils or leaves, there is welding and fabbing required. Like as mentioned, there is lots of stuff on FSB as they have a whole section devoted to SAS'. Also, wt4x.com a good write up done by my buddies mark and dave.
I am running a 60 front and sterling rear on coils with 40" mtr's (similar to the set up in the wt4x4 writeup). My rig can be seen at
http://www.superford.org/registry/ve...il.php?id=1278
Old Dec 22, 2004 | 01:57 PM
rlh's Avatar
rlh
I put a link to a thread showing how a tone ring for the VSS in a D60 was done but it was removed within and hour after I posted.
Let's try a different link, click her>D60 rear tone ring install
Edit: Some vans had D60s with tone rings. Some D61 had tone rings as well which could be adapted to a 60.
