weird electrical thingy
Old Oct 10, 2004 | 05:49 PM
73effie's Avatar
73effie
Im hoping that you wizards can help me identify a part. it is a metal plug thing in the drivers door jamb and is labeled as a ford part. #DZAF-12A164. it has 2 wires coming from it. what is it and what does it do? its from a 73 f100 shorty.
appreciated, eddie-
Old Oct 10, 2004 | 06:17 PM
Mil1ion's Avatar
Mil1ion
That would be a:
Distributor Modulator Ambient Switch
That Z is wrong though.
Could it be a 2 ?
Old Oct 10, 2004 | 06:40 PM
73effie's Avatar
73effie
what exactly does it do, million?
Old Oct 10, 2004 | 06:45 PM
WillyB's Avatar
WillyB
"Distributor Modulator Ambient Switch" ---- what in the world is that, and what does it do? Retard your spark when it is hot/cold? Talk of retards - - -
Mil1ion's Avatar
Mil1ion
http://www.google.com/search?hl=en&q...=Google+Search
Old Oct 10, 2004 | 07:05 PM
WillyB's Avatar
WillyB
Thanks, I think. Your Google search (plus the one I did) did not turn up any information that jumped out at you - if there is an explanation in that mess I did not see it.
You remind me of the blue-haired old lady that attempted to teach me English back in the 50's - any question about a word was answered "look it up in the dictionary!"
Guess I will have to go through life not knowing what a "Distributor Modulator Ambient Switch" does.
Old Oct 10, 2004 | 07:40 PM
ranger429's Avatar
ranger429
Distributor Modulator Ambient Switch??? What the?? Mil1on, I as well did not see anything that jumped out at me with your google link. I would suspect that this switch is supposed to advance or retard the timing depending upon the temperature outside? I have yet to come across a switch like this, is it something that was used in certain mountainess area's of the world or something?
Old Oct 10, 2004 | 07:56 PM
78F1504X4's Avatar
78F1504X4
I think he's yanking yer chain. It turns on the dome light.
Old Oct 10, 2004 | 07:59 PM
ranger429's Avatar
ranger429
I thought the same thing but mil1on isn't one to play game's like that. You should have seen what I was gonna post!!
Old Oct 10, 2004 | 08:06 PM
78F1504X4's Avatar
78F1504X4
Maybe it's the answer to the next funtest? He hid the last answer in a thread.
Old Oct 10, 2004 | 08:11 PM
Mil1ion's Avatar
Mil1ion
The courtesy/dome light switch is > 13776 & 13777
That Z means a service part.
Therefore, it may have been superceeded.
Old Oct 10, 2004 | 08:14 PM
glenn 79's Avatar
glenn 79
I just replaced them on my truck today. Now I have a dome light that
works when you open the door. I was getting use to turning the headlight
switch when I need the light.
Glenn
Old Oct 10, 2004 | 08:18 PM
WillyB's Avatar
WillyB
Found it - or Google did. I did a search on that part number and Google returned me to this forum - https://www.ford-trucks.com/forums/a...ex.php/t-92746
The question was from greenhighboy-- CAN ANYONE TELL ME WHAT THE SMALL ELECTRICAL UNIT IS, IN THE FORWARD JAM OF THE DRIVER DOOR ON MY 72 F-100??? IT CARRYS A Ford part NUMBER..D2AF-12A164-B4..ITS GOT TWO WIRES COMING OUT THE BACK...BRN W/ORNG, AND RED W/YELLOW. ITS ABOUT 3/4 IN. ROUND WITH TWO EARS FOR THE ATTACH screwS, AND IS BESIDE THE DOME LIGHT, DOOR SWITCH.
The answer was from Tom C. ---- That is a temperature senson for the emission control system. Look on the passenger side firewall and there is/was as solenoid with 2 vacuum lines and a wire harness plug. There is as switch on the transmission to sense high gear. The advance vacuum is cut off above a certain outside temp. when the transmission is in the lower gears.
TomC.
That blue-haired English teacher would be proud of me!!!!
Old Oct 10, 2004 | 08:39 PM
Mil1ion's Avatar
Mil1ion
Ahem,,,,,ahem .......
Old Oct 10, 2004 | 10:17 PM
WillyB's Avatar
WillyB
Guess mil1ion is also proud of me!
