Sponsored by: Real Truck
Auto Hubs Question
Old Oct 10, 2004 | 05:38 PM
Big Sky's Avatar
Big Sky
Auto Hubs Question
I just returned from a speed goat hunting trip and drove on some greasy, muddy roads. When the hubs are in the auto position (2000 F-250), it seems that the front end doesn't lock up when I turn the **** to 4x4, but when the hubs are in the locked position, the front end works great. Any ideas on what the problem could be?
Old Oct 10, 2004 | 10:13 PM
wlihntr's Avatar
wlihntr
get any prong horns on the trip? the front hubs in the auto pos. are vacuum operated, if they are not engageing in that pos you may have a vacuum leak some where. if you turn on the heater to the floor pos. and then try to switch it in to 4 wheel drive and the air starts comming out the defrost pos. then it is a vacuum leak(with a lose of vacuum the hvac will always send air to the defrost )
Old Oct 11, 2004 | 01:33 PM
Big Sky's Avatar
Big Sky
We bagged an 11.5" buck right away. Is this repair something I can do myself (mechanically inclined), or do I have to have someone else fix this for me?
Old Oct 11, 2004 | 02:03 PM
wlihntr's Avatar
wlihntr
if you can find the leak and its in one of the lines its pretty easy. sometimes they leak from the hub seal(which would have to be replaced). i have never done it myself, maybe someone that has will chime in
congrats on the buck... i leave for elk and deer hunting friday
