fuel injection electrical problem
Old Oct 10, 2004 | 04:28 PM
codiakbr_65550's Avatar
codiakbr_65550
can't figure out why on my 1989 f150, 5.0L, EFI system not getting juice to injector electrical connector, used test noid at injector with no electrical juice there, have replaced eec relay but no luck, HELP
Old Oct 10, 2004 | 04:43 PM
mike93's Avatar
mike93
check at the EEC harness connector. check for continuity using ohm meter.
Old Oct 10, 2004 | 06:16 PM
EPNCSU2006's Avatar
EPNCSU2006
The red injector wires should get power from the EEC relay, which also powers VPWR inputs on the computer, pins 37 and 57 if I remember correctly. Check for continuity between these points as Mike said. A wiring diagram would help you out very much. Also make sure your grounds are making good connections.
Old Oct 15, 2004 | 07:33 PM
codiakbr_65550
thanks guys gonna work on it again this weekend, need to get it fix before deer season
adamshee
Dec 12, 2014 02:09 PM
3drhino
May 8, 2014 05:35 PM
jimmielee
Aug 13, 2012 04:49 PM
Tom Norton
Feb 15, 2011 10:01 AM
tjc transport
Jun 13, 2006 04:08 PM
