Sponsored by: Kumho
Severe Front End Shake
Old Oct 14, 2004 | 06:58 PM
96-5spd302's Avatar
96-5spd302
Originally Posted by eastvanmikee
just did the track bar bushings on my 79 bronco. ps Napa has a split bushing so you wont need a press to put the new ones in..hope this helps
Do you think that a bronco would have the same track bar as my truck? Napa keeps saying they are not showing one for a F-350, so if it is the same I will just order for a Bronco.
Old Oct 14, 2004 | 10:24 PM
teds74ford's Avatar
teds74ford
The bars don't even look the same, so they probably are different. Still, it wouldn't hurt to see if 79 bushings fit. the track bar on the leaves is there (I think) because the shackle is in the front. This keeps it centered since the motion of the axles will be more moved by bumps in relation to the steering than if the shackle is in the rear of the axle, similar to the solid axle chevys. I don't know if I said that clear or not, but hopefully I did. Ted
Old Oct 15, 2004 | 05:36 PM
96-5spd302's Avatar
96-5spd302
Well I got the shake fixed. I went to Ford today and got track bar bushings. Put them in and had to shim the axle a lil bit cause it was laid back to far, due to the add a leaf. Works great now, still a lil shake round 40-45 but that is my tires
At least now I can drive it. Thanks for all your help!!
