Explorer Tailgate
Old Oct 10, 2004 | 01:34 PM
RyanExplr04's Avatar
RyanExplr04
Explorer Tailgate
I was wondering how do you take the plastic pannel off the inside of the tailgate .... Do you just pop it off or is there another way because I don't want to break anything by trying to force it off....
Old Oct 10, 2004 | 03:15 PM
VTBrian's Avatar
VTBrian
There are plastic rivet-like binders that Ford uses holding it in place. My understanding is that there is a tool you can buy from any auto supply store that allows you to more easily pop these off. If not, you can take your chances with a screwdriver. It takes a little work, but they just pop out and hopefully without being damaged. Hopefully, you can reinstall them, otherwise, it would be a relatively inexpensive item from the dealer for a set of additional rivets.
I hope the comments help.
Old Oct 10, 2004 | 07:37 PM
staffbuoy's Avatar
staffbuoy
just had mine off to replace the wiper motor.screws along the top take the strap off and where the lock is there is a screw under that pop the cap off .
Old Oct 10, 2004 | 09:26 PM
Ponyracer's Avatar
Ponyracer
be careful, 94 and earlier have screws at the top and at the lock **** under the trim panel and have push pins to pop out. 95 and later have the screws and the slide up to come off no push pins.
coastaldc
Jan 18, 2017 10:39 PM
jonrjen
6.7L Power Stroke Diesel
35
Aug 21, 2015 08:39 PM
95bogginbronco
Paint & Bodywork
Aug 15, 2006 08:58 PM
JoshMan
1997 - 2003 F150
Aug 29, 2003 08:58 PM
evo-pete
Jun 15, 2003 03:51 PM
