Transmission troubles...
Old Oct 10, 2004 | 10:59 AM
aged toad's Avatar
aged toad
My 92 f-150, 4.9, E4OD, 261Kmiles is having problems. The transmission engages,(easily felt) but the truck doesn't move much. There is a "buzzing" noise from the trans, that changes pitch with rpm's. Filter and fluid have been changed with no improvement. Suggestions?
Old Oct 10, 2004 | 11:24 AM
yellowjeep76's Avatar
yellowjeep76
It's probably one of the many friction clutches or bands that are used to engage the gears. You are probably looking at a rebuild or replacement. Shop around and find a good transmission shop that can look at it and give a good diagnosis. You have quite a few miles on that transmission so its not uncommon for it to need a rebuild.
Old Oct 15, 2004 | 08:34 AM
aged toad's Avatar
aged toad
Thanks, but before my poor old beast goes to a shop, I'll get a replacement trans from a boneyard. I was kind of hoping that someone had similar problem and could steer me in a specific direction such as torque converter, solenoids, pump...
Old Oct 15, 2004 | 11:45 AM
Fords4Me's Avatar
Fords4Me
Arrow
Maybe try the trans forum. Lots of good stuff there.
