56 radiator replacement?
Old Oct 9, 2004 | 06:22 PM
learpilot's Avatar
learpilot
Hey guys, its time for me to start looking for a radiator for my 56. Ran across a deal on a stout 351w out of a nascar showcar so I'm going to need a good hd radiator. I plan to use an electric fan setup. Is there one that I can find from a donor vehicle that will do the job, needs to have a trans cooler for the AOD or Will I have to buy a new unit, Any suggestions would be a big help. Thanks
Old Oct 9, 2004 | 09:54 PM
Purple55's Avatar
Purple55
I used one out of about a 99-2000 Explorer. 4 core aluminum with plastic tanks.Did very little trimming to make it fit in my 55.
Old Oct 9, 2004 | 11:02 PM
packrat56's Avatar
packrat56
I put a MODINE #395 in my 56, got it new from a radiator shop for about $170. I had to drill two holes, other than that it fit like it belonged there. I have a 302 with a tranny cooler seperate out in front of the rad. Should check with the rad shop to see if is enough cooling for your application.
Old Nov 10, 2004 | 09:09 AM
packrat56's Avatar
packrat56
Learpilot, got your message but your settings do not allow me to email you. The Modine fit in my 56 like a glove, it does not look stock. but sure is NOT too tall. Would you like me to measure it and post the measurements?
Old Dec 24, 2004 | 06:36 AM
peppermintfatty's Avatar
peppermintfatty
You might try Blue Oval Truck Parts, http://blueovaltruckparts.com/ , They have radiators for V-8 applications, starting at $250.00 for standard duty, for heavy duty, add $30.00, and "desert cooling" add $60.00. Choose inlet and outlet locations, and manual or automatic trans. Just another option, I hope it helps.
Jeff
