Quick fix??
Old Oct 9, 2004 | 05:56 PM
hockeyplurr's Avatar
hockeyplurr
Question Quick fix??
What could I do to the rust around my fenders to stop it from spreading I think im going to spray some stuff out of a rattle can paint it with black spray paint and put some fender flares over the rust what do u think???
Old Oct 9, 2004 | 06:20 PM
68torino's Avatar
68torino
Rust-Mort or Por-15
You have to treat it right or cut it out. If not it will continue to grow and worse will flares.
Old Oct 9, 2004 | 10:01 PM
hockeyplurr
I went out and got rust treatment thats in a rattle can and sprayed it on all the rust. Tomorrow I think Im going to get some that I can brush on so it gets the nooks and crannys good. Then Im going to use filler and fill in the fenders.
Old Oct 10, 2004 | 11:01 AM
68torino's Avatar
68torino
I would put rust treatment inside also. That is where the rust sneaks up on you.
Old Oct 11, 2004 | 10:31 AM
weymouth's Avatar
weymouth
I've used Ospho, applied with both a chip brush and a trigger spray bottle. Protect your skin & eyes when you use it. I'd suggest using a spray bottle to get a decent amount up into the area between the wheelhouse and the outer fender. I'd also suggest doing it a few times, letting it set for a day between each application. Then, if your up to it, empty a can of Rustoleum, or better Zero-Rust, into the same area. Be at the ready to wipe off any overspray or drips that might come through to the outside surface.
