Bronco II Ford Bronco II
Window Moldings
Old Jan 26, 2001 | 02:39 PM
Boss_358's Avatar
Boss_358
Window Moldings
Does anyone know if the molding around the rear side windows can be replaced or is it made on to the windows. The molding on my 90 Bronco II is starting to shred apart and want to fix it but have not taken the window out yet. I have found good windows with perfect molding but do not want to have to replace my good windows if I can just replace the molding. Thanx for any info.
78 Ranger 4x4 351C-4V
83 Ranger 302
90 Bronco II 2.9
Old Jan 26, 2001 | 07:15 PM
Avanti's Avatar
Avanti
Window Moldings
In my 89 Ford Shop manual it states "remove all the moldings, nuts & studs before you pull the glass. It looks like you go in side and take the trim off around the glass, than undo nuts that are attached to the moldings. It looks like you can pull the molding fairly easy but I could be wrong.
89 Bronco II XLT
93 Aerostar AWD
92 F150 XLT ext cab
Old Jan 28, 2001 | 02:10 PM
jbrote47's Avatar
jbrote47
Window Moldings
