timing chain install
Old Oct 8, 2004 | 03:33 PM
del250's Avatar
del250
Question timing chain install
Never installed one before. Engine is back together. Its a 351m 77 or 78. Wont start prety sure I have the distributer in correctly and timed at 8 btdc. crank was turned with chain off. Could it be the timing chain is off, if so how would I check with out pulling it apart again.
thanks
Old Oct 8, 2004 | 03:57 PM
del250's Avatar
del250
The marks on the gears for the chain were lined up. I dont know if it can be 180 off or somthing.
thanks Derek
Old Oct 8, 2004 | 06:29 PM
78_ford_F150's Avatar
78_ford_F150
did u put the dist in right
Old Oct 8, 2004 | 06:47 PM
del250's Avatar
del250
Got it going, it must have been the dist. Just started over with installing the dist and must of got it right.
Thanks Derek
