7.3 lifters
Old Oct 8, 2004 | 12:36 PM
rbdutton's Avatar
rbdutton
Question 7.3 lifters
I know on a gasser, it is recommended that if you change either the lifters or cam, you change both. What about the roller lifters on a 7.3? Can you get by changing just the lifters? I have one that is starting to "tick" and now know why I lost a valve. Think it is the same lifter that caused the problem originally. I am thinking of changing all the lifters and push tubes.
Old Oct 8, 2004 | 06:02 PM
89ford73's Avatar
89ford73
i wouldn't worry about changing the cam if it has roller lifters. but im not 100 percent either way that they even have roller lifters. if they do then change just the lifters. if not, i would go with both.
Old Oct 9, 2004 | 12:35 AM
Spectramac's Avatar
Spectramac
Yes they are rollers. They are quite spendy so only change one if you have to.
