94 302 surge
Old Oct 7, 2004 | 09:49 PM
tb_clark's Avatar
tb_clark
Angry 94 302 surge
I have a 94 F-150 4X4 that has surge when idling. The truck has 233000 miles and I rebuilt the motor. It had the surge before and now it is back but only at idle and only if you dont feather the throttle down. If it is doing it and you put the truck in gear it stops doing it. I changed the egr valve and checked the tps and iac both are fine. I have replaced all vacuum hoses and used propane to try and find a vacuum leak but to no luck. It is also getting good fuel pressure and fuel return. Does anyone have an idea.
