squeaking noise
Old Oct 7, 2004 | 08:18 PM
99stocksport's Avatar
99stocksport
squeaking noise
i have a question for yall: whenever i go around a corner going more that 25mph i can hear this high pitched squeaking noise, and i think that is it coming form the front right wheel...and i was just wondering if yall knew what that might be, and if it is a major problem
thanks
Old Oct 8, 2004 | 11:10 AM
sjwoody's Avatar
sjwoody
At first, one would think it would be a suspension problem because it happens in a corner. But if it were me, I would pull the front tire and check the brakes. If they're worn, replace them and then see if you still have a problem. You might even be able to duplicate the squeak with the wheel off and turning the rotor.
