Help settle a debate.
Old Oct 7, 2004 | 08:11 PM
StorminMarv's Avatar
StorminMarv
This guy at work swears up and down that he has a C6 that is bolted to a 302. He says that "it is a small C6". It is my understanding that the C6 only fits the "big" blocks. Is he be correct?
Old Oct 7, 2004 | 08:21 PM
WhëëlMå1's Avatar
WhëëlMå1
Why not ask the guys in the transmission forum?
Old Oct 7, 2004 | 08:41 PM
Chris_ce's Avatar
Chris_ce
I have a c6 in my bronco It was hooked up to a 351w. They do have them for small and big blocks. Little tidbit of info here. Did you know that bigfoot runs a c6.
Old Oct 7, 2004 | 09:10 PM
pfogle's Avatar
pfogle
The C6 trans comes in 3 bellhousing sizes, small block V8 and I6, big block V8, and the Diesel bellhousing. So yes he has a C6 behind his 302.
DeckedoutF150's Avatar
DeckedoutF150
my grandpa worked in sharronville where they made the C6 and we also had a 1988 F150 with a 351 and a C6. the C6 is used in alot of high performance applications. alot of drag cars use them as well. it was a tough trans.
Old Oct 7, 2004 | 10:04 PM
Jimmy Dean's Avatar
Jimmy Dean
I have had a 302 bronc with a factory C6. also a 150 302 with a factory E4OD
Old Oct 7, 2004 | 10:21 PM
wizzard351's Avatar
wizzard351
dont forget the ol'FE, they had a c6 for them as well. wasnt the old deisels the same as a460 bell?? just wanderin never messed with any other than gas.
Old Oct 8, 2004 | 12:07 AM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
Old Oct 8, 2004 | 07:30 AM
Casey's Avatar
Casey
I used to have a 300 inch 6 cylinder with a C6.
Old Oct 10, 2004 | 06:34 PM
SoCalDesertRider's Avatar
SoCalDesertRider
Yeah the diesel and 460 use the same bell pattern but the trannys use different starter mounting for the diesel, so I am told. I have a C6 behind my 351W/5.8L too.
