General Automotive Discussion
help with engine trouble code
Old Oct 7, 2004 | 07:24 PM
lazybones's Avatar
lazybones
My second vehicle (not my F250 )is showing a check engine code which I don't understand. I'm hoping that somebody can explain and perhaps offer some fix suggestions. The code that came up was PO441 "EVAP emission control system purge flow fault" ? ANY ideas would be appreciated.
Thanks
Old Oct 8, 2004 | 12:03 AM
Torque1st's Avatar
Torque1st
Posting Legend
What kind of vehicle is it?
Old Oct 8, 2004 | 06:05 AM
lazybones's Avatar
lazybones
sorry, Its my 10 year old (95) c220 mercedes.
Old Oct 8, 2004 | 08:07 AM
wycowboy79's Avatar
wycowboy79
Thats an OBDII code. The most likely cause for tripping that code is a loose or defective gas cap. Tighten the cap at LEAST 3 clicks after fueling, if you always do that anyway, replace it, it may be the cause. The next most likely cause is the vacuum hose to the EVAP canister is missing or cracked. After that, the purge or vent solenoid on the gas tank is defective and last, you may have a vacuum leak at the engine somewhere.
Chris
i eat hybrids
May 20, 2017 10:15 PM
hhcobra
Jan 2, 2010 08:53 PM
kjg26
Aug 26, 2006 06:16 PM
famf23
Feb 26, 2005 06:32 PM
Wakeboarder141
1978 - 1996 Big Bronco
19
Oct 31, 2004 11:50 AM
