Bronco II Ford Bronco II
no fuel
Old Oct 7, 2004 | 04:44 PM
vmaxjim's Avatar
vmaxjim
no fuel
New to this room. Just bought 86 bII. Truck has no fuel. Nothing coming from back pump, high pressure seems ok, never heard run. Inertia switch seems ok. Any help? Jim
Old Oct 7, 2004 | 05:25 PM
Help I M Stuck's Avatar
Help I M Stuck
fuel pump in tank working?
Old Oct 7, 2004 | 07:52 PM
Ken00's Avatar
Ken00
Check for power to the intank pump since you indicate the HP pump is working. If you have power then you'll need to drop the tank.
Old Oct 9, 2004 | 11:35 AM
vmaxjim's Avatar
vmaxjim
supposedly prior owner stated possible bad groung wiht battery connection. Will check the connction now. Jim
Old Oct 11, 2004 | 08:20 PM
vmaxjim's Avatar
vmaxjim
Turns out it was a bad ground from battery. But last night it died out again. Pump is ok. Will check the green relay for pump 'cuz it doesn't look so good. Jim
