Day-time running lights
Old Oct 7, 2004 | 01:07 PM
captaincanuck's Avatar
captaincanuck
i have a 93 ranger xlt 3.0, problem is my day-time running lights flicker or flash, i dont notice this happening all the time just every now and then, anyones opinion would be great except telling me to turn my full lighting system on, thanks
Old Oct 7, 2004 | 07:57 PM
racsan's Avatar
racsan
well i dont know if you ould want to do this or not, you may not be able to legally, (im guessing from your name you are in canada, dont know about the law there) anyway, if you dont want D R L anyway, you may be able to pull a fuse that controls only that, i did that to a pontiac montana i once had. aside from that, id check for a loose/bad ground wire. it may be easier to run a new wire from ground (or hot, could be that lead also) then it would be finding the open spot in the wiring. good luck! Dave.
Old Oct 7, 2004 | 08:46 PM
Ken00's Avatar
Ken00
I'm think the module might be going bad, I believe the module delivers a pulsed voltage to the lights, might be able to grab one at a junkyard cheap.
Old Oct 8, 2004 | 10:10 PM
allanlepage's Avatar
allanlepage
The module would be my bet - it's a few inches away from the radiator on the drivers side. I got one from a junk yard.
Old Oct 8, 2004 | 10:23 PM
PatG's Avatar
PatG
How can you tell if your truck has drl? My 2000 XLT Sport S/C 3.0 has everything else, but in checking to see if there is any lights, the only thing I see lit up is the background on the switch. Any hints?
Old Oct 9, 2004 | 09:54 AM
captaincanuck
I think they are only i n canadian vehicles, i could be wrong, still having trouble with the flickering
Old Oct 9, 2004 | 06:44 PM
Ken00's Avatar
Ken00
You would have a module behind the drivers bumper, mine has the wiring harness there with nothing connected to it.
Old Oct 10, 2004 | 09:31 AM
captaincanuck
i'll check that out, thanks
