EG analayzer for FE?
Old Oct 7, 2004 | 07:50 AM
FORD352V8's Avatar
FORD352V8
Lightbulb EG analayzer for FE?
Hmmmm, I see that summit has this thing that you somehow hook to your exhaust and then it tells you what your air/fuel ratio is. I have always tuned my carbs by ear. I am wondering, is it worth the $150? Its got 3 little lights, and when you have the "perfect" mixture the middle one lights up. Anyone tried these? Is it a superior method to tune with this gadget, or is it best just to go by what sounds and feels right?
F3V
Old Oct 7, 2004 | 08:38 AM
gtex's Avatar
gtex
sounds a bit pricey. you can get an O2 sensor and a A/F guage for less.
My questions. Do most of us with dual exhaust need 2 sensors? I have an H-Pipe, could I put it there? I guess that might be too far from the collectors, no?
Ford352V8 , what is the part number you are looking at?
edit: I just priced a Summit Digital A/F gauge with 2 weld ni bungs and 2 sensors...$97 plus shipping. Might be the way to go. Just put a switch in to monitor each side of the motor...or spend another $30 and get another gauge.
Old Oct 7, 2004 | 11:31 AM
rusty70f100's Avatar
rusty70f100
No, you only need it in one side. Both sides will run identically anyway, why would you need it in both sides?
When I put the O2 sensor in for my fuel injection, I put it in the collector of the right side header. It's worked good there. I dont think the Holley ECU even has the capability for multiple O2 sensors.
Old Oct 7, 2004 | 02:48 PM
gtex's Avatar
gtex
I just thought having one on each side would help diagnose problems..bad valves, cam lobes, ignition etc...You might at least be able to tell which side to look at?
Old Oct 7, 2004 | 03:22 PM
Six Niner's Avatar
Six Niner
i always thought you had to have one in each side to get a reading on both sides. my 88 stang had two. but then i may be way off to.
Old Oct 7, 2004 | 04:27 PM
BB's Avatar
BB
I tune my vehicles with a commercial exhaust gas analyzer just to make sure there are no surprises come smog check.
I found a blown head gasket with one, stuck the sniffer in the radiator (making sure not to suck up coolent).
Only problem is I can't drive around with it unless I get a really long extension cord.
Old Oct 7, 2004 | 07:07 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
F/A meter
Ford352V8, i'm running a Auto Meter gauge, i think it has 17 LED bars vs 3 that you stated. I used a Cyberdyne for years before. I installed the Auto Meter in a piece of exhaust pipe that mounts under the dash on a bracket. The mount has a large orange LED in a metal tube, this lights when the micro switch on the secondaries begin to open. On the bottom is a switch to read left and right bank O2 sending units. When i switched from and old 1850 holley that had alot of jet changes to a 670 holley, it was jetted perfect out of the box. Had a plugged air bleed, gauge showed it. A fuel pump that had a slow death the gauge responded long before the butt felt the motor lean out.
Gauges are our friend. Carl......o&o>...........
