IP question
Old Oct 7, 2004 | 05:52 AM
dieselkis's Avatar
dieselkis
IP question
Hello
Does anybody know the size of the socket that fits the bolts that holds IP to the gear wheel?
Old Oct 7, 2004 | 08:24 AM
89ford73's Avatar
89ford73
it is a 5/16-fine thread bolt with a 5/16" 12-point head . has to be a 12 point, you might be better off using a 5/16 wrench that is what i had to do. and do not pull the half moon aluminum housing off, that gear in there is really hard to get lined back up right, i almost went crazy when i did that to mine. for the 3-9/16 bolts that are hold the i.p. on to the aluminum housing, get an old 9-16 wrench and grind down the round end of it to make it a little more skinny, this will help a lot.
Old Oct 7, 2004 | 09:23 PM
bilder12's Avatar
bilder12
You will also have to remove the nuts a little at a time while backing out the pump. Dont loose any little parts inside the front cover.
