Pulling the engine
Old Oct 6, 2004 | 11:54 PM
DenisMcG's Avatar
DenisMcG
Pulling the engine
I have a fairly bad oil leak as well as a cracked exhaust manifold. I would like to pull the engine and do the work in my garage. How difficult is it to pull. It is an 89 F-150 with a 302 and 4-speed T-18 trans.
Thanks
Old Oct 7, 2004 | 12:06 AM
andym's Avatar
andym
It's an awful lot of work just to fix an oil leak and replace a manifold. Have you considered doing the work while the motor's in the truck?
Old Oct 7, 2004 | 12:10 AM
DenisMcG's Avatar
DenisMcG
Yes, my original thought was to do everything with the motor in the truck. I was just wondering how much work it might be to pull the engine. I will probably just leave the motor in and do it that way.
Thanks,
Denis
Old Oct 7, 2004 | 12:37 AM
Toolman1973's Avatar
Toolman1973
I'm in the middle of swapping my 302 with a 351.... its a peice of cake
if you do pull the motor, make sure you label everything or better yet .. take pictures
thanks
toolman
Old Oct 7, 2004 | 07:19 AM
alabamabuddog's Avatar
alabamabuddog
Pulling the motor is a piece of cake like said above. I pulled mine and didnr label anything. With the FORD conectors you would be hard pressed to cross them up, although pics are very good for a refrence
