transmission crossbar??
Old Oct 6, 2004 | 10:39 PM
bils50f1's Avatar
bils50f1
Hey guys, i was woundering if i use a new transmission crossbar (in my 1950 ford f-1 with a 302) for a newer 4 speed manual (any good ideas for what transmission to use?)would i have to remove my old crossbar and replace it with the new one or how does this work. cause i heard that the crossbars are bolt in so that would proabably dictate where my engine mounts would go right?? i am getting slightly confussed by all of this maybe i should just buy the things and see what it looks like... any help would be great, thanks,
-Bill in Wis.
Old Oct 6, 2004 | 10:46 PM
Woodsman_30350's Avatar
Woodsman_30350
Bill,
I went with a crossmember with a built-in brake cylinder mount for my 50 F-1 with a 351W/C4. Didn't quite work with my aftermarket power brake pedal and M/C. Now changing to a bolt in mount from TCI for the 48-52 Ford. Hope it is what I need.
Old Oct 7, 2004 | 09:42 AM
gdub's Avatar
gdub
I cut the center out of the original cross member and then made a bolt in section with the new trans mount on it. If you go with a new crossmember you will have to remove at least part or all of the old one.
Old Oct 7, 2004 | 08:36 PM
jniolon's Avatar
jniolon
old and in the way
Bill,
just mount your engine and transmission and make your own crossmember...
https://www.ford-trucks.com/article/...1956_F100.html
john :-x06
wogdiml
Dec 25, 2009 08:08 AM
StevoF1
Apr 19, 2009 06:32 PM
2005Xplorer
May 4, 2007 07:13 AM
bombero21
Jun 10, 2005 09:04 PM
karljay
Nov 29, 2004 06:22 AM
