Bronco II Ford Bronco II
Fuel Pump problems..HELP!
Old Jun 12, 2001 | 09:52 PM
wrm2tch420's Avatar
wrm2tch420
I have a 89 Bll 2.9L. It acts like it isn't getting gas.. alot of the time.. other times it runs fine. Took it to a shop and they told me the fuel pressure was at 20 and was supposed to be at 35. Said my fuel pump was bad. I changed that out along with the fuel filter under the Bronco. It ran great for a week then started the same thing!When I changed the pump,I took the case the pump was inclosed in apart and ONLY changed the pump and filter. Think maybe that has something to do with it?
Old Jun 13, 2001 | 09:03 PM
thelonerangerxlt's Avatar
thelonerangerxlt
420, Since this problem is intermittent, I don't think the pump case has anything to do with it. Your trouble could be in the fuel pump relay; I think it's on the passenger side fenderwell on your model. Good luck.
"Nothing lasts forever except natural stone and old Ford trucks." (Willie Nelson)
Old Jun 14, 2001 | 07:11 AM
wrm2tch420's Avatar
wrm2tch420
It's not on that fenderwall. Only fuse box and voltage regulator.I changed the fuel pressure valve yesterday with no luck. Was told also it might be the MAP sensor, thats on the firewall. I'm no mechanic so please give me some idea as to what it even looks like. Oh also when driving when it starts acting up.. if you let off the gas some, it does a little better for a few mins.If you give it gas, it wants to shut off. Usually it won't go over about 40 unless you manage to get up speed.
Old Jun 14, 2001 | 08:12 PM
thelonerangerxlt
420, the MAP sensor (manifold absolute pressure) is about 2"x2", has a plug wired into the wiring harness, and is almost at the level of the hood, the highest point in the engine compartment. It's on the firewall toward the center, but maybe slightly on the driver's side.
However, I don't think that is the problem. The symptoms you describe sounds like the MAF or speed density sensor. I think your model has the speed density type of fuel injection. This sensor is located on the air filter box, between the box and the throttle body, and also has an electrical connector.
These sensors get dirty and give an erratic throttle response, and a loss of power. To change it, you will need a "tamper-proof" allen wrench that auto parts stores sell. The sensor can also be cleaned with an O2 sensor safe throttle body cleaner. Sometimes cleaning works, sometimes it dosen't.
Hope some of this helps. Don
Old Jun 14, 2001 | 09:54 PM
wrm2tch420's Avatar
wrm2tch420
Thanks Don for your sugestions. I will look into that.ANY sugestions are appreciated.
Old Jun 15, 2001 | 09:32 PM
broncoii4x4's Avatar
broncoii4x4
You may want to check your fuel pressure regulator and/or the low pressures fuel pump located in gas tank if so equipped. I know the '87 model has it, not sure about the '89.
Old Jun 16, 2001 | 09:47 PM
wrm2tch420's Avatar
wrm2tch420
[font size="1" color="#FF0000"]LAST EDITED ON 16-Jun-01 AT 10:47 PM (EST)[/font][p]Changed out the fuel pump again today... It wouldn't even pump fuel.. So i went back and bought the whole case.. Installed it.. By the way i'm getting VERY good at fuel pump installations.. and it fired right up and drove without any problems! 3 pumps and i'm on the road again! Hope it lasts this time..
I was told the little rubber ring the pump sat in was losing the fuel pressure making the fuel return back into the tank.
Thanks you guys for all your help! Good to know i have a place to turn to for answers to my questions..
Kathy
Old Jun 20, 2001 | 04:14 PM
gimps's Avatar
gimps
