9 inch for 89
Old Oct 6, 2004 | 02:52 PM
88treadbrite_150_4spd's Avatar
Question 9 inch for 89
i have 9 inch rear end out of a 79 bronco and i want to put it in my 89 f150 4x4 will it be a simple bolt in job or do i need to change a lot of things. thanks in advance.
Old Oct 6, 2004 | 03:48 PM
andym's Avatar
andym
It'll both right in, but you'll lose your ABS. Also make sure the gear ratio matches up with your front axle, or you'll break something when you try to use it.
Old Oct 7, 2004 | 12:00 AM
so it will just bolt in thanx for the help.
