Here is a picture of my project truck. The only modification that has been done is someone removed the cats and put a very sorry *** dual exhaust system on it. This will be corrected hopefully next week. Should I go with a single 3" or true duals again?
I have a new set of BFG T/As mounted and RS9000 shocks installed, what an improvement to the ride.
Where should I start? It will be used to pull my 4000lb tractor, making runs back and forth to the Depot and general light playing.
I want to get the drive train perfect and then make the body perfect. The truck seems to be a good base to start with. I do have to have the transfer case gone through, there seems to be quite alot of slack when in 4wd.
