Bronco II Ford Bronco II
b2 surging
Old 10-05-2004, 05:24 PM
egrice3's Avatar
egrice3
egrice3 is offline
Question b2 surging
I have a 87 Bronco II that surges when it you press on the accelerator. It will not take off smooth but surges. It's almost impossible to park in tight spaces because it surges. In addition, it sputters and cuts back when I try to hold the speed at about 35mhp. When I press the peddle it picks up but will return when I try to hold a certain speed. The problem seems worst when the tank is less than full and when the weather is hot. The truck drives better overall when it is cool. I have replaced the points, plugs, wires, cat converter, fuel pump, oxygen sensor, thermostat, and the problem is still there. Any ideas?
Old 10-05-2004, 05:41 PM
Avanti's Avatar
Avanti
Avanti is offline
surging
I would check the fuel pump pressure. How many miles do you have on the fuel pumps? Sounds like one or both are getting weak.I would suspect the one in the tank is the primary culpret as it is affected by the tank volume.
Old 10-05-2004, 05:47 PM
Avanti's Avatar
Avanti
Avanti is offline
Also I made a hole thru the trunk of my BII so I could pull the fuel pump with out dropping the tank. I made a plate to cover the hole. Lasted 3 years.
Old 10-05-2004, 09:34 PM
mrshorty's Avatar
mrshorty
mrshorty is offline
Along with checking the fuel pressure, pull any trouble codes from thecomputer.
Old 10-06-2004, 05:50 PM
egrice3's Avatar
egrice3
egrice3 is offline
The exterior fuel pump is new. Someone suggested blowing out the fuel line as well. I'll check the pump in the tank.
02GrayPowerStroke
1997 - 2003 F150
03-04-2017 08:01 AM
sdawe
10-07-2016 11:55 AM
02GrayPowerStroke
1997 - 2003 F150
09-11-2016 08:17 PM
orphius
02-14-2011 05:35 PM
mackedisto
10-14-2005 05:17 PM
Quick Reply: b2 surging
