Electrical and motor surging
Help, this currently has me befuddled. I have an '04 F250 that is surging rythmicly. The Idle RPM seems to hold steady for the most part but it sounds as if the load on the motor is going up and down, up and down. It also has my head lights going bright then dim, bright the dim. I also get a flickering battery light that keeps time with the surging. The pace of the surging seems to get faster with more load on the motor. This usually has little effect on the motor but things get worse when it is cold out. Any one have any ideas?
I doubt it's load related, unless it's a really screwed up Glow Plug Control Module. That's about the only thing that I can think of that would put enough load on the electrical system to be that noticeable. You could unplug the GPCM and see if it goes away, that would eliminate that problem.
If it is related to the alternator, I would more suspect a really screwed up voltage regulator.
improvement54
03-17-2015 08:15 PM
1riverside
03-28-2014 06:49 PM
ztuck
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
04-04-2006 11:07 AM
