Painting Steering Wheel
Old Oct 5, 2004 | 05:51 PM
dlhngrs's Avatar
dlhngrs
I am wanting to paint the steering wheel in my 1969 F100. I usually use DuPont's Centari. Has anyone ever done this and, if so, with what and what were the results? I don't know if any special preparation of the surface or any special primer is required. At the moment I am running the steering wheel through the dishwasher to clean it. Will appreciate any help.
David
Old Oct 6, 2004 | 10:09 AM
Jag Red 54's Avatar
Jag Red 54
I painted mine with rustoleum primer then rustoleum color coat. Works for about 5 years, then needs recoat. John
Old Oct 6, 2004 | 12:04 PM
thesprocket26's Avatar
thesprocket26
I have heard that there is a classic steering wheel restoring kit out there. I thought mine was black but was actually blue. The last guy spreyed over the original.
Old Oct 6, 2004 | 04:21 PM
jzjames's Avatar
jzjames
What color do you need to paint it?
I needed to paint mine that "Ford white" original color and used
Epoxy appliance paint - the almond shade. Matched almost perfectly, and I have found the epoxy paints very durable. Take alot of time to prep - fine sanding and feathering the wheel completely. For your first coat when painting with a spray can, just mist the entire surface. This will give your finish coats some 'bite' and will prevent runs. jz
