65-66 spindle question
Old Oct 5, 2004 | 01:09 PM
biggut's Avatar
biggut
Question 65-66 spindle question
I just read, with great interest, the tech article by Dennis K. Austin; about disc brake upgrade on a 65-66. This looked like a good place to start, so I went to the local wrecking yard with my list of parts. The head guy said they didn't have a 74, but they had a 75. He looked on his computor, and said the spindles are exactly the same part #. The article specifically called for spindles from a 74. Can anyoune tell me what the difference is, if there is any? The guy is taking them off right now, and said he'd guarantee they are the same. Thanks, Brett
Old Oct 5, 2004 | 03:42 PM
scamardo's Avatar
scamardo
I am pretty certain they are the same. I 99% certain that spindles from 73-79 will work. I used 73 spindles on my 65 and it was a direct swap.
Old Oct 5, 2004 | 04:25 PM
ddavidv's Avatar
ddavidv
I used ones from a '79. Yep, they are the same.
Only difference is kingpin retainer location, so you just use the correct kingpin as needed.
Old Oct 5, 2004 | 06:07 PM
daveengelson's Avatar
daveengelson
Used 75 donor truck. Believe can swap out and interchange most, if not all, i beam parts between 75 thru 79; whereas, limited to one or two choices between 72 and 74. Also, would not deal w/ donor master cylinder, not sure what you get. Purchased a new one thru NAPA for $45, no exhange required. I also used the same pressure switch for stop lights but had to modify an adapter purchased at Napa. Used same petal setup using 1/2" square alum stock cut about 3" as spacers between firewall and M C bracket. Anyhow, you will be getting number of different suggestions on best method of making the upgrade. Here is another article, did not compared articles to determine if duplicating. http://www.mongrelmotorsports.homest...f100discs.html
Dave
Old Oct 6, 2004 | 06:15 AM
jowilker's Avatar
jowilker
Brett, There are several items in that article that I don't agree with and wish Ken would up date it. But that is his call.
There are two ways to put discs on your slick, one is the spindle swap. If your king pins are still good, beating the hello out of them is an aweful lot of work that I think is unnessessary. The 73-79 exchange is a direct bolt up, a lot faster and easier IMHO. If the front end was lined up on the donor it will be lined up on the reciever.
my 2
John
Old Oct 6, 2004 | 11:28 AM
EconoDan's Avatar
EconoDan
Are you saying a complete axle swap, John?
I'm building my dream truck in my mind.....hope to get something like what scamardo's got....
If I can just bolt-up front and rear axles from a 76-79.....add PS and PB (same years).....would that be better than the " 65/6 body on a 76-9 frame" option?
(am I makin' sense?)
Dan
Old Oct 7, 2004 | 06:07 AM
jowilker's Avatar
jowilker
Dan, My 66 F100 has a complete 76 F150 front axle set under it. From radius arm nut to radius arm nut. There are enough cheep donor 73-79 trucks with spent bodys and or engines that can be picked up for a couple-three hundred bucks, that you should be able to find one with good king pins. You and a bud could drop two sets of axles and install one in a half day. You will need some large wrenches a long and big pry bar and a jack. You want to move everything complete including the coils.
After doing this myself twice and helping many others, my next move will be to build a truck on the later chassis. Cab & front clip bolt holes are the same on the chassis from 65 to 79. As in another post this morning, start a plan.
I would like to go to Fla. and learn from a master like FBPete and upgrade my back yard shade tree skills. My problem has always been no place to work and no money.
John
redstarr1000
Apr 12, 2015 09:33 AM
ridealong34
18
Jan 15, 2014 08:22 PM
Ziegelsteinfaust
Feb 14, 2011 04:55 AM
Blackwaterforge
23
Apr 28, 2008 03:56 PM
