1978 - 1996 Big Bronco
backin up
Old Oct 5, 2004 | 12:27 PM
freakmagic's Avatar
freakmagic
Exclamation backin up
Alrighty i have a 1982 ford bronco the problem is of no back up lights but i have checked everything so where would i get the sensor for the lights? Also is it norma lfor the valves to be knocking at 55 miles an hour? If any one could help it would be greatly apprcieated.
Old Oct 5, 2004 | 03:37 PM
greystreak92's Avatar
greystreak92
If you have an automatic transmission, the switch for the backup lights is combined with the neutral safety switch in the transmission. If you have a manual there will still be a switch in the tranny to trigger the backup lights, just different from the neutral safety combo in the auto.
Old Oct 5, 2004 | 04:20 PM
Kemicalburns's Avatar
Kemicalburns
just what grey said.
your valves are knocking? are you sure. whats your oil pressure at. is there plenty of oil in the motor?
Old Oct 6, 2004 | 08:24 AM
freakmagic's Avatar
freakmagic
Plenty of oil it is when it warms up about 55 she rattles like a son of gun. also every blue moon on start up. the guy i bought it from said he replaced the valves and rockers. i havent looked yet until i can get a idea on a heads up.
Old Oct 6, 2004 | 08:49 AM
Kemicalburns
i wouldnt drive it tell you figure it out. could have bent valves or bad lifters. have you checked the timing? it should be between 8*-10* btdc with spout connector removed. but this could do more harm to your motor driving it.
Old Oct 6, 2004 | 09:59 AM
freakmagic's Avatar
freakmagic
just set the timing and its good i figure that it would be the lilfters so i am going to check this week. if it is none of that do yo uthink it could be the oil pump?
Old Oct 6, 2004 | 11:13 AM
greystreak92
If it was the oil pump you would have spun a bearing or thrown a rod by now. Like Kem said, how's the actual oil PRESSURE. Lots o' oil doens't necessarily mena its getting everywhere it needs to. I would tend to believe its sticky lifters more than anything. Might try a detergent product like CD-2 in place of a quart or 2 of oil. But do make certain you are getting good oil pressure before you go driving it. Sticky lifters are still less expensive than stuck pistons!
Old Oct 6, 2004 | 11:57 AM
Hamfisted's Avatar
Hamfisted
Sea Foam it ....
The oil passages could be clogged up allowing the lifters to collapse at higher rpm. Try running some Sea Foam in it for a while to flush out the passages. Then do an oil change using any filter except Fram.
Sea Foam's Website
Mike
'96 5.8L EB
Old Oct 6, 2004 | 01:59 PM
BillyBob69's Avatar
BillyBob69
OK..What is it about the Fram filters that I dont know that I should? I have used them many times and haven't had any probs...yet?
Old Oct 6, 2004 | 03:54 PM
andym's Avatar
andym
They're the absolute cheapest and poorly made filters on the market. I wouldn't use a fram on a lawnmower.
Old Oct 6, 2004 | 10:29 PM
BillyBob69's Avatar
BillyBob69
LMAO OK I dont think it will take much more for me to figure that one out. Thanks or the info. What would you suggest?
Old Oct 7, 2004 | 10:03 AM
greystreak92
Kem, if you really want to drain your life savings you can put a Mobil One filter in it! They are fantastic filters but you will spend upwards of $12 on one.
Old Oct 7, 2004 | 02:28 PM
mustangman65_79's Avatar
mustangman65_79
I use motorcraft filters now
