Bronco II Ford Bronco II
Over Heating Problem Solved
Old Aug 8, 2001 | 10:23 PM
TowerMaster's Avatar
TowerMaster
Well It turns out that I had the wrong fluid mixture in the coolant system. I went to a 50/50 instead of a 70/30... And the problems went away. I must say that having the double row radiator did help out on my 5 speed manual OD tanny. Went on a camping trip, towed it up hills, down into valleys and it stayed right in the middle. It does climb a little after I have been running it hard,when I come to a stop, but as soon as a get going again it comes back down...That is normal basically on all cars. Considering there is no air movement accross the radiator. I was thinking about using a flexfan with a non-thermo fan clutch. But I dont think so, I dont want the gas millage to go to the craphouse.
Old Aug 11, 2001 | 07:34 PM
Boss_358's Avatar
Boss_358
How did the coolant mixture effect the manual transmission when they dont require a cooler?
People who say it can't be done should not interrupt the person doing it.
Old Aug 12, 2001 | 01:03 PM
TowerMaster
It wasnt my Tranny overheating, It was my engine... And having the wrong coolant mixture has alot to do with everything... Straight Antifreeze has a freezing point of zero degrees, which also means that the boiling point will also be lower.
Old Aug 12, 2001 | 01:08 PM
TowerMaster
krustiy lusti
18
Apr 9, 2017 07:22 PM
riggermortis
1966 - 1977 Early Broncos
Dec 11, 2016 12:59 AM
BigBlue2
Oct 23, 2016 08:22 PM
wildcard221
Jul 30, 2014 10:51 PM
2FordTrucks
15
Oct 20, 2013 10:38 AM
