351W stroker question
First off, I don't know too much about muscling up a engine, aside form bolt-ons. I have installed a K&N system, new Y pipe, high flow CAT, Flowmasters and dual exhaust. Next is headers, intake manifold, ignition sys, distributor, throttle body, alternator, electric fan and maybe a chip. Anyway, I am wanting to really amp this thing up so I decided on making it a stroker since I have been hearing a lot of good things about them. There is no replacement for displacement they say. What I was hoping for is some pros and cons, I'm having a hard time deciding between going to a 393 or a 408. I will probably go for the 408, it seems to make more sense to me. I will admit that I barely know what it means to bore a motor out or do some offset grinding and this is certaintly something that I haven't done before. But it sounds great and money really ain't to big of an issue. I have been doing some reading and getting some ideas but once again I am pretty much starting from scratch on all the technical stuff like crank throw and lift specs. I also know that to benifit from making a stroker I need a kickass combination with rod to stroke ratio, cylinder heads, etc. I have heard great things about AFR cylider heads and Twisted Wedge heads. So any info would be great. What do you guys know and what do I have to do to make me a kick *** stroker?
