horn
Old Oct 4, 2004 | 01:07 PM
msinger's Avatar
msinger
horn
I replaced steering shaft, cant remember hook up for horn ! black plug, other?
Old Oct 4, 2004 | 01:36 PM
qman's Avatar
qman
Horn wire is the blue with yellow stripe coming out of the bottom of the steering column. If you trace it up to where it plugs into a plastic piece under the steering wheel, you'll see a about 1 1/4 inch piece of cylindrical plastic (smaller diameter than a pencil) that sticks up and is hollow. Into this cylindrical hole should be horn blowing ring contact brush. It serves the same purpose that a brush does in a starter or alternator. It allows electrical contact between a stationary (steering column) and a moving (steering wheel) part. If you dropped this little bugger when you replaced the shaft, your horn won't work until you put it back.
Old Oct 4, 2004 | 02:10 PM
msinger's Avatar
msinger
thanks, cant find brush, is there a replacement
Old Oct 4, 2004 | 02:50 PM
qman's Avatar
qman
Yeh, go to this online retailer's catalog: http://www.dennis-carpenter.com/pdf/67-72_truck.pdf
Part # C20Z-13A821-A.
$9 and its on p. 38. There's even a picture.
Old Oct 5, 2004 | 04:05 PM
msinger's Avatar
msinger
have two black wires, 1 to male clip , other not sure of
Old Oct 5, 2004 | 04:20 PM
qman's Avatar
qman
I'm assuming these two wires come off the back of the horn button. The one you're not sure of is probably V-shaped. You just push the V down into one of the 2 bolt holes in the base of the steering wheel that you use to screw in a steering wheel removal tool. That is your ground.
Old Oct 5, 2004 | 06:25 PM
msinger's Avatar
msinger
thanks it is v shaped, i'll give it a try, thanks
bigred22769
Mar 18, 2019 09:40 PM
js74f250
May 12, 2016 04:31 PM
vidaliaman
Jan 27, 2016 01:09 PM
Leatherneck007
Jun 26, 2014 05:43 AM
JByrd1173
Exhaust Systems
Nov 14, 2004 03:45 AM
