Fuel Tanks Venting Concerns
Old Oct 3, 2004 | 10:28 PM
53Merc's Avatar
53Merc
Question Fuel Tanks Venting Concerns
Twinned Stock Fuel Tanks + 5.0L SEFI
Has anyone ever had venting problems with a Fuel Injected System?
I've twinned two stock tanks on my 1953. The first is in the stock slant cab position under the driver on the running board supports, the 2nd is under the passenger, also on the running boards in the reverse position. I have connected them with a length of 1" fuel hose (same as is on your neighbourhood gas station pump!) from the low side front corners
The SEFI pick-up and return goes to the original position tank and the system is vented from the top of the 2nd tank up through a hose that exits 4" below the front of the box out the back of the cab. I can smell gas far too often and have been trying to diagnose the problem. without success
I've deleted the smog pump and charcol filter and wondered if that was the problem.
Has anyone done this and solved this issue?
Old Oct 4, 2004 | 08:17 PM
Dealford's Avatar
Dealford
I haven't had to deal with your type of situation myself.
Just a thought here...If you were to run a line up to the air intake & plumb in just before the throttle body, you could use a PCV turned backwards ( in case the engine backfires, it will close the valve).
Of course, a charcoal canister would work too.
Venting the tank to open air has no choice but to allow gas vapours to escape.
AL.
Old Oct 4, 2004 | 09:28 PM
Mil1ion's Avatar
Mil1ion
Moved to Fuel delivery forum
Please feel free to posts tech questions in the tech forums
Old Oct 4, 2004 | 09:45 PM
53Merc's Avatar
53Merc
Thanks Al & Dennis
Gerry
1966Tbird
Sep 24, 2012 01:19 PM
robinmke
Feb 13, 2012 11:37 AM
Hotairjunkie
Jul 20, 2009 05:08 PM
Manwith3fords
18
Feb 29, 2004 04:34 PM
Jim_1
Offroad & 4x4
Jan 17, 2000 03:57 PM
