Sponsored by: Real Truck
Air Horns
Old Oct 3, 2004 | 08:28 PM
JohnDeereGuy's Avatar
JohnDeereGuy
Air Horns
Hey guys, I just bought a set of air horns for my truck today, and was curious how you guys have wired them. I did a search for this topic and found out that I probably shouldn't wire the compresser to the existing horn wires. I want the compresser to run off of the battery but I also want to use the horn button inside the steering wheel. Any suggestions on how I should wire this up? Oh and is there any way other than taking the inner fender moulding out to get to the factory horn. Thanks again.
Old Oct 3, 2004 | 08:33 PM
refuse2's Avatar
refuse2
I would use the original wires hooked to a relay and from the relay make it to were it crosses over to the battery, because I don't think that the original wires can handle that much of a load for very long before burning up or blowing fuses.
refuse2
Old Oct 3, 2004 | 08:44 PM
TNT in Round Rock's Avatar
TNT in Round Rock
which horns ?.. I want to put a set of LOUD air horns on my F250
Old Oct 3, 2004 | 08:51 PM
JohnDeereGuy
these are actucally cheap plastic air horns from a truck stop, 40 bucks. I hope they work well and I'll let ya know how they turn out. Thanks for the wiring info, that's just what I needed. I just moved to college and the traffic is terrible, and I like to get people to move when there stopped at a green light. Thanks
Old Oct 3, 2004 | 08:59 PM
mikewrt's Avatar
mikewrt
yes relay is the way to do it. what does your compressor say for current draw? I would just wire into the horn switch under the dash near the fuse panel. I think the wire you are looking for is a dark blue and is a negative activated wire in the steering column harness. Don't forget to unhook your existing horns!! Lets HEAR how they turn out!!
Old Oct 4, 2004 | 08:02 AM
rmilchman's Avatar
rmilchman
My gallery shows my install (but not the wiring). Does your compressor have a tank? If you need help wiring let me know and I can send you same basic steps.
Old Oct 4, 2004 | 09:08 PM
jyddad's Avatar
jyddad
I just finished mounting a Grover 27 inch stutter horn (actual fire truck horn) with a one gallon tank and compressor on my 05 F350. I mounted the horn under the truck below the drive's door area and the tank and compressor on the frame rail. I wired the compressor to the orange wire that is part of the trailer wiring. I installed an inline 15 amp fuse. I actually tied the wiring for the horn button to the same wire. I located the button on the drivers kick panel. It is activated by my foot.
I was concerned about having the airhorn sound when I locked my doors.
Old Oct 4, 2004 | 09:12 PM
TNT in Round Rock
what did that set up cost ???
Old Oct 4, 2004 | 09:25 PM
JohnDeereGuy
It cost about 40 bucks, I rigged them up tonight. I don't have a air tank, just an electric compresser. I was actucally not very impressed with the sound, It's loud but almost like one of them air can horns. They will work for now but if I come across some from a Peterbilt I will be getting them put on. Thanks for the help guys.
Old Oct 5, 2004 | 04:57 PM
hillyrd's Avatar
hillyrd
Love that application Jyddad,
I bet you sure can get their attention with that bad boy horn!!!
Good idea about a separate switch.
Old Oct 5, 2004 | 05:23 PM
JFWalker's Avatar
JFWalker
I tried air horns many years ago. The problem arose from mounting the horns in the engine compartment. The hood, radiator, grill etc. really muffled the sound. They were loud, but not as loud as they could/should have been.
Another horn I tried later, was the horn used on a diesel locomotive. As with the air horn, mounting in the engine compartment it wasn't as loud as it could/should have been, but it sure was an interesting sound!
Old Oct 5, 2004 | 10:00 PM
rmilchman's Avatar
rmilchman
You could always mount them under the cab
Old Oct 6, 2004 | 01:04 AM
jake00's Avatar
jake00
where did you get a 1 gallon tank?
